Long smoke test run
Hello, I uploaded my Docker for the PAN 2026 Generative AI Authorship Verification.
I tried to run smoketest for the task on your website and it has been testing/running state for about 4-5 hours already. Could you please check if everything is okay with the execution? or if there is any issue with my Docker image/submission?
Thank you. :slight_smile:
For some reason I wasnt able to see the output. Log out and log in again helped.
This is already solved.
Cool, thanks for the update!
