Not valid input datafile
When I run the following line :
tira-run --dataset pan25-generative-ai-detection-smoke-test-20250428-training --image submission:latest --command ‘. /.venv/bin/activate && python3 modelo_final.py ${inputDataset}/dataset.jsonl ${outputDir}’
neither using this:
tira-run --dataset generative-ai-authorship-verification-panclef-2025/pan25-generative-ai-detection-smoke-test-20250428-training --image submission:latest --command '. /.venv/bin/activate && python3 modelo_final.py ${inputDataset}/dataset.jsonl ${outputDir}
I have the next error :
File “/modelo_final.py”, line 320, in
dic = evaluate_model_predictions(modelo, inputDataset, output_dir )
File “/modelo_final.py”, line 232, in evaluate_model_predictions
df_val = preparar_dataframe(path_val)
File “/modelo_final.py”, line 186, in preparar_dataframe
df = json_to_dataframe(json_file)
File “/modelo_final.py”, line 46, in json_to_dataframe
with open(json_file, ‘r’, encoding=‘utf-8’) as file:
FileNotFoundError: [Errno 2] No such file or directory: ‘/tira-data/input/dataset.jsonl’
I believe the dataset is not being automatically downloaded to the folder.
Thanks for helping :face_holding_back_tears:
Hi @mjimgon,
Thanks for your participation in the task!
Could you please invite @thagen and me (our accounts are theMrSheldon and mam10eks) to the github repository with your code? Then we can have a look there.
I have just invited you as collaborators. I hope you can find anything in there…
Thanks again.
Awesome, thanks!
Thank you very much!
I responded to you with a DM
Thank you so much for your help!
I’ve uploaded my code following the submission instructions. Hopefully, everything goes smoothly—fingers crossed!
Unfortunally, i have a new error :
i have try both, uploading my code and a docker
  1. ‘’‘tira-run --input-dataset generative-ai-authorship-verification-panclef-2025/pan25-generative-ai-detection-smoke-test-20250428-training --image entrega-ba205 --push true’‘’
  2. ‘’‘tira-cli code-submission --path ./ --task generative-ai-authorship-verification-panclef-2025 --dataset pan25-generative-ai-detection-smoke-test-20250428-training’‘’
and after 1 hour (in both cases, and i’ve tried multiple times) i get the following error :
I dont know if my image is too heavy or if i’m doing again something wrong.
Again, sorry to bother. It’s my first time
We are already working on this in a private chat, it looks like the problem are network timeouts :slight_smile:
