Problem with tira api key
Dear Organizers,
I would like to submit my Docker image for the Multiauthor Writing Style Change Detection competition. However, I am currently having trouble finding the correct API key for the TIRA client.
According to the information I found on the forum, the API key for a team should be visible after clicking on the “Submit Docker” tab. I was able to locate an API key there, but when I try to use it, I receive an error message indicating that the key is not valid.
Could you please advise me on how to proceed or confirm whether the API key displayed is the correct one for Docker submission?
Thank you in advance for your support.
Ewelina
Dear Ewelina,
Thanks for reaching out, the key linked to your team was expired, and the UI currently does not yet handle to automatically recreate expired keys.
I deleted the old key and verified that the new key assigned to your team works, so everything should be fine now.
Now it works! Thanks!
Awesome, thanks for the update!
