Problems with LLMs on Local Machine and Local Testing
Hi I can’t run the docker on the cloud where I used the LLM and on my local machine I don’t have the power. I uploaded the LLMs on HuggingFace and created a GitHub Repo. Could you submit it from there? Thanks in advance :smiley: .
Hi, sure, this is no problem, could you please invite me to your Github repo, I can submit it from there.
Thanks :slight_smile:
Dear @filip.milak,
Everything worked :slight_smile:
The software got uploaded under the name marinated-edge, and I started it on all datsets, on the 2025 dataset it already produced valid results, everything looks good so far.
(the results will be unblinded shortly after the deadline.)
