Hi Maik, thanks for the earlier clarification on the hosted models. We uploaded a code submission (team feup-dei, software similar-coda) using --forward-environment-variable OPENAI_API_KEY OPENAI_BASE_URL OPENAI_MODEL, as in the solving-smolagents baseline README. Starting it in TIRA on business-trip-spot-check-20260907-training fails with “The forwarded environment variables require network access that is not permitted for this task.”
Is there a way to run a submission in TIRA on the spot-check datasets against your internally hosted models (gpt-oss-20b/120b, Qwen2.5-7B), so we can validate the hosted-model path before the deadline?
For the final evaluation, is a software registered with these forwarded variables run correctly, i.e. with your internal values injected? Or should we upload it differently? Without the variables, the mandatory local test of tira-cli code-submission cannot produce output for an LLM-based solver.
Is the vLLM server started with tool calling enabled (--enable-auto-tool-choice with a --tool-call-parser per model)? Our agent uses native tool calls (tools, tool_choice="auto"), unlike the official baselines.
What is the max-model-len per model, and are reasoning_effort and response_format (JSON schema) accepted?
Dear Pedro,
The software does not start because we configured that it only can run with network access to some pre-defined hosts.
We therefore start the software ourselves, please allow that this might require a few days (Usually, we try to run everything on the same day, but sometimes it might take a bit longer). We start the LLM Models via their default parameters, so no tool calling is enabled. I will reach out to you in a private message to resolve this.
Hi Maik,
We are not uploading any further software. These are our five final submissions, in priority order:
Task |
Software |
TIRA ID |
| 1 |
Task 2 (solving) |
teal-proposal |
docker-software-5277 |
| 2 |
Task 2 (solving) |
beige-flamingo |
docker-software-5184 |
| 3 |
Task 1 (retrieval) |
immense-champagne |
docker-software-5275 |
| 4 |
forgiving-vault |
docker-software-5276 |
| 5 |
vertical-electrolysis |
docker-software-5186 |
Could you confirm that this message is enough to designate them? If you need them registered another way (a form, a flag in TIRA, or a different split between tasks), please let us know.
One request about the re-executed runs. On 18 October, between about 18:20 and 19:50 UTC, some spot-check runs got APIConnectionError: Connection error on every LLM call. For the selected software these were:
forgiving-vault: 2026-10-18-19-09-11-47298eb6, 2026-10-18-19-08-22-52cae063 and 2026-10-18-19-44-19-06ad1f26
immense-champagne: 2026-10-18-19-47-49-1ef5bece
Our retrieval software falls back to the lexical ranking when this happens, so these runs are valid, but they only measure the baseline. Since the test runs are blinded, we cannot check them ourselves. Could you check whether any test run of these five submissions hit the same endpoint outage, and re-run it if so? Re-running the four spot-check runs above would also help, but is less important.
Thanks again for all the support with the runs.
Pedro Soares
