We got this error while using the github actions:
Run tira-cli login --token ***
INFO:root:No settings given in /home/runner/.tira/.tira-settings.json. I will use defaults.
WARNING:root:Set DOCKER_HOST to 'unix:///var/run/docker.sock'. Prevent this by explicitly setting the environment variable DOCKER_HOST.
✓ You are authenticated against www.tira.io.
✓ TIRA home is writable.
✓ Docker/Podman is installed.
✓ The tirex-tracker works and will track experimental metadata.
Result:
✓ Your TIRA installation is valid.
TERM environment variable not set.
Ensure that you are registed for task retrieval-augmented-debating-2025.
TIRA Code Submission:
✓ You are registered and will submit as team leonhard-euler to task retrieval-augmented-debating-2025.
The dataset "retrieval-augmented-debating-2025/retrieval-augmented-debating-2025/rad25-2025-01-16-toy-20250116-training" is not publicly available in TIRA. Please visit https://tira.io/datasets for an overview of all public datasets.
File "/opt/hostedtoolcache/Python/3.8.18/x64/bin/tira-cli", line 8, in <module>
sys.exit(main())
File "/opt/hostedtoolcache/Python/3.8.18/x64/lib/python3.8/site-packages/tira/tira_cli.py", line 360, in main
return args.executable(**vars(args))
File "/opt/hostedtoolcache/Python/3.8.18/x64/lib/python3.8/site-packages/tira/tira_cli.py", line 235, in code_submission_command
client.submit_code(
File "/opt/hostedtoolcache/Python/3.8.18/x64/lib/python3.8/site-packages/tira/tira_client.py", line 312, in submit_code
dataset_handle = self.get_dataset(f"{task_id}/{dataset_id}")
File "/opt/hostedtoolcache/Python/3.8.18/x64/lib/python3.8/site-packages/tira/rest_api_client.py", line 214, in get_dataset
raise ValueError(msg)
ValueError: The dataset "retrieval-augmented-debating-2025/retrieval-augmented-debating-2025/rad25-2025-01-16-toy-20250116-training" is not publicly available in TIRA. Please visit https://tira.io/datasets for an overview of all public datasets.
Error: Process completed with exit code 1.
