hallo, i get some error messages :Problem While Loading the Docker Images.
This might be a short-term hiccup, please try again. We got the following error: Error: Error fetching endpoint: TIRA with 500
Thank you for your help.
Hi @szb,
Sorry for the inconvenience, an authentication key in the background was not created, I resolved this, it should work now.
Hello, the issue mentioned earlier has been resolved. I now have a new question. I am participating in the Generative Plagiarism Detection task. I downloaded the training data from TIRA, which includes a “pairs” file and some TXT documents. However, when I was testing, I noticed that the input is a JSONL file. I would like to confirm: is the input file format supposed to be JSONL?
Thank you very much!
the format contains some pairs file and some txt documents.
The format of the datasets should be identical: https://www.tira.io/datasets?query=plag. (You can expand the row to see the format of the data)
So the test data and the spot-check data is in the format you described. Could you link me to the location where you found the different format? This seems to be an error.
Hi, I encountered this problem too. How should I resolve it?
Hi, thanks for contacting me!
I refreshed the authentication for your accont, this should work now.
