Dear Admin
I followed the tutorial “step-by-step guide on how to use very big models on A100 GPUs” to upload the pre-trained models I used,When I’m working on Step 2: Upload the Model Weights to TIRA,I found that there is no way to upload models that require token authentication.Even if I add token in front of the model name, it doesn’t work.
Dear Lyu,
We can resolve this manually, I contact you in a direct message to clarify the details (basically that we manually download the private model).
