Before submitting, check your data online.
Open the task’s submission page.
Click on SUBMIT, registering your team if necessary.
Click on ADD UPLOAD GROUP.
Click on EDIT to set the dataset’s title, description, and link (will be used in the compiled dataset’s README).
Select your dataset file and the input dataset ‘submit’.
Click UPLOAD RUN
Wait about 15 minutes. Then reload the page and check your submission.
NOTE: Create a run upload group for each dataset you provide, but overwrite old versions of a dataset by uploading again in the respective upload group.
