Dear Organizers,
I recently submitted my solution on TIRA and tested it on both datasets. While the output for the multi-author-writing-spot-check dataset appears to be valid, I encountered an issue with the multi-author-writing-20250503-test dataset, the output seems invalid, and I cannot view the details of the run.
Would it be possible to get some guidance on how to debug this issue or access more information about what went wrong?
Thank you in advance for your support.
Ioana
