Hi there,
I have been trying to submit my result today. I installed Tira client and successfully finished local testing, however, when I try to push my work, I encountered the following bug:
########################################### Review the Outputs of your Software ############################################
Your software produced the following outputs in /home/miramoe/Desktop/Lab/DockerTest/tira-output.
Please shortly review them before we push your software.
- result.jsonl: 250 bytes
Are the outputs correct and should I push the software to TIRA? (y/N) y
Push Docker image
I tag the image “weihanghuang/jaha-gaiav” as “registry.webis.de/code-research/tira/tira-user-jaha/weihanghua:latest” for upload to TIRA (only internal).
File “/home/miramoe/anaconda3/envs/gaiav-jaha/bin/tira-run”, line 8, in
sys.exit(main())
File “/home/miramoe/anaconda3/envs/gaiav-jaha/lib/python3.11/site-packages/tira/tira_run.py”, line 313, in main
image = client.local_execution.push_image(args.image, registry_prefix, args.tira_task_id, args.tira_vm_id)
File “/home/miramoe/anaconda3/envs/gaiav-jaha/lib/python3.11/site-packages/tira/local_execution_integration.py”, line 358, in push_image
self.show_docker_progress(line, tasks)
File “/home/miramoe/anaconda3/envs/gaiav-jaha/lib/python3.11/site-packages/tira/local_execution_integration.py”, line 341, in show_docker_progress
tasks[id].update(line[‘progressDetail’][‘total’])
KeyError: ‘total’
Pushing (5f70bf18a086):: 0it [00:00, ?it/s]
Any help or advice would be highly appreciated. Many thanks in advance.
