Run review and unblinding the results
Once you completed your software, tested it on training dataset and executed it on test dataset in your virtual machine or by uploading the archive, you can run evaluation of you results.
The respective task organizers are regularly checking the submitted evaluations and review them.
You can contact them stating your VM name and the respective shared task that you are participating via pan@webis.de.
