Hello, there
When I tried to submit
Command:tira-run --input-dataset multi-author-writing-style-analysis-2024/multi-author-spot-check-20240428-training --image clef:0.2 --command ‘python /home/clef/model.py’
Error:tira-run: error: argument {upload}: invalid choice: “/home/clef/model.py’” (choose from ‘upload’)
I tried a lot of solutions, repackaging the image, changing the path, but never solved the problem
Dear @cookie0,
It looks like the python /home/clef/model.py is not parsed as one string, but as two strings so that tira-run thinks that /home/clef/model.py is an independent argument which does not exist.
The reason for this is likely that the quotes are wrong. I.e., it should be ', but it currently is ‘ in the example that you pasted.
Could you please try this command:
tira-run --input-dataset multi-author-writing-style-analysis-2024/multi-author-spot-check-20240428-training --image clef:0.2 --command 'python /home/clef/model.py'
(I.e., with the ' as quote and not ‘.)
Does this solve the problem?
Awesome, thanks for the response!
Please do not hesitate to contact me/us in case of questions/problems.
(We regularly review submissions and contact in case we see problems)
