My Tira API key seems to be problematic
Dear Organizers,
I’m trying to submit a Docker image for the Multiauthor Writing Style Change Detection competition, but I’m having trouble with my Tira API key. I found an API key on the forum, but it’s not working.
Could you please confirm if the displayed API key is correct for Docker submissions?
Thanks for your help.
Best regrads,
hellojie
Dear @hellojie,
Sorry for the inconvenience! Tere was indeed an error with the key, I updated it. It should work now :slight_smile:
