Awesome, nice that this worked!
It is likely due to the load (i.e., it might take a while until it gets scheduled), I look into this.
Perfect, it looks like it just finished while we were writing ![]()
Ah yes I saw it.
But I am confused.
What is considered the final submission?
Do I have to make the “Run the software”? I thought that is just for verification.
Can I delete the runs under submission?
Also under “Choose Software” I see two options ecru-digital and uniform-beans. Which one is the final one?
Kind regards.
usually, the organizers will at some point reach out to you to clarify what the final submissions of you are. You and/or the organizers can delete runs and/or submissions (that are not final).
Every time when you execute tira-cli code submission and this works without error and the --dry-run flag, it creates a new submission. But you and/or the organizers can delete obsolete submissions.
You can have multiple submissions for the task, if there are too many (which depends on the task and on the submissions), the organizers might ask you to prioritize your submissions.
Okay. But just to clarify the individual runs are actually not necessary to execute? What counts is the submission?
You can already start the individual runs, this would be perfect.
(we try to start them anyway, but when you start them it is less likely that we overlook something :))
best regards,
